hi, i have the same problem. where did you change the mtu size for the srt stream?
thank you very much!
Hi Sorry
I am not that good to be able to explain
We did two things : change the speedfusion settings to a Nat mode
And change the rules âsend all traffic toâ with an outbonding rule
To be honest, I donât know what worked in the end
Machtl via Peplink Community a ĂŠcrit :
My question was more about the mtu change @gerson.brands mentioned.
Edit: You have to change the MTU size of your streaming device. You have to check if and where itâs possible on your device.
Hi Machtl,
it depends on your SRT-Streaming device. On that device you can change the MTU size (not on every device).
Iâld recommend to use FW 8.1.0 or the 8.1.2 if youâre using SRT and your device is not able to change the MTU
Best wishes from Munich
Dennis
Thx, yep thats the problem, i canât change the MTU settings on the SRT-Streaming device itself. Danke dir, schĂśne GrĂźĂe aus OberĂśsterreich.
So, FW 8.1.2 was now released, does it solve the SRT Streaming issue? Thx!
I´m showing my issues :
Block diagram attached:
Backpack unit with MAX BR2 PRO, with two 4G/5G SIMs; LTE/4Gâ5G antennas on SIM1 (Slim model); on SIM2, internal antennas; and two WiâFi zone antennas for the Sony PXWâZ200 camera as SRT caller to the destination at the MCR studios.
Reception at the MCR studios with B One, connected via WAN to one or two ISPs with a fixed public IP,which will deliver, over LAN, the cameraâs SRT connection to a player such as VLC ora video server such as OBS, for example.
The link between both ends is via SpeedFusion.
I can´t change the MTU at the camera, is not available in it´s menuesâŚâŚ
Items to be defined:
- How to configure the LAN IPs at both ends (MAX BR2 PRO and B One):
how the subnets and masks should be set up for Layer 2 and Layer 3 connectivity scenarios.
- What configuration should the MAX BR2 PRO WiâFi connection use to connect a device
such as the camera?
- What settings must be configured on the Peplink devices to allow SRT streaming?
SRT ?
What requirements must the WAN connection on the B One meet?
Which devices should be configured for DHCP and which should use static IPs?
What is the required SRT URL format on the camera?
Are any ports required?
And the basic diagram :
