Speedfusion with Peplink 305/380
We have multiple Peplink 305’s and 380’s. I had read that when using PepVPN if we set the WAN priority to the same priority for all our WAN links, that Speedfusion bonding would kick in. We have 3 WAN connections, but whenever I try to set them all to 1-Highest, it will not allow this. It only lets me select 1,2, or 3 etc. Is there something else that I need to do in order to activate speedfusion? We are using the tunnel as a Layer 2 tunnel. It was my understanding that both of these models came ready to use at least 2 speedfusion peers. I believe the 380 has more capability in the number of peers, but the 305 should come with 2 correct? I do have the option to activate a speedfusion trial on the web interface, but I didn’t think I had to use a trial.
Danny
The number of peer licenses controls how many peer devices that you can create a PepVPN connection to .
eg. Device A (a 305 with 2 licenses) could make PepVPN connections to devices B & C
To activate SpeedFusion connection bonding, you would still need to activate that feature. It should be standard on your 380, but requires a separate license for the 305.
