SpeedFusion vs PepVPN
Basic Setup: I setup a speedfusion connect cloud bonding multiple sources and created/assigned a VLAN/SSID and outbound policy to use it (no PepVPN setup). I connect to that VLAN/SSID for my video conferences and speedfusion looks to be working correctly (Status/Speedfustion page shows data going across the included sources).
My question is should I also be using PepVPN in “some way” in my basic setup above? (i’m not sure how pepvpn fits in the equation and the main use case for when/why to utilize. it.
PepVPN is the underlying VPN capability to create a tunnel between two devices (or in your case the device and SpeedFusion Cloud). SpeedFusion VPN is the ability to build multiple PepVPN tunnels on multiple WANs and use them at the same time.
