We are using Speedfusion with two LTE. There is alot of dropped packets on UDP and we want to switch to TCP port for Data transmission. Any suggestion on how to setup data port as TCP.
SpeedFusion uses UDP port and this can’t be changed.
Thanks for the ifno. Is there any plan to support TCP in the near future. Furthermore, for our network setup it is important for us to use TCP connection. is there anything that can be done ?
You have opened ticket and provided more info there. We will follow up with you in ticket.
Thanks.
