Hello can you help me resolve this problem evant log: SpeedFusion (refused connection made from an unknown peer) both on pepwave max700 and balance 580. Thanks in advance
You should able to see the serial number of remote peer based on the log above. Please login to that remote Balance/Max router to disable SpeedFusion/PepVPN profiles which is not using.
