What’s the throughput of Speedfusion WITHOUT AES for the following models ?
310,
380,
580,
710,
1350
Regards,
HA
310,
380,
580,
710,
1350
Regards,
HA
Below is a link that should help you about your inquiry. Halfway down will have a section titles “SpeedFusion Throughput” on the left side that lists what each devices rated throughput is.
Best Regards,
Jarid Petermann
Generally speaking, you can expect the SpeedFusion throughput to approximately double when AES 256 is turned off.
Hello Tim,
Thanks for the infos.
Regards,
HA
