SpeedFusion: multiple devices per side of tunnel
#1
Could a customer use two HD4s on the same SpeedFusion Tunnel while attempting to go to a Balance or FusionHub?
The purpose for this request would be greater bandwidth bonding. Their site wants 8 LTE ‘pipes’ instead of the 4 of a single HD4.
I suppose this request starts to get into EPX territory. But the question of multiple physical devices on one side of a SpeedFusion tunnel is unfamiliar to me.
Looking forward to any feedback. Thanks all!
#2
The HD4 will build the SpeedFusion tunnel separately to the Balance or FusionHub. You can’t make both HD4 to use the same tunnel. I think EPX is the choice if you need to have a same SpeedFusion tunnel with 8 cellulars.
#3
How about connecting the first HD4’s LAN port with 4 ethernet cables to the 4 WAN port of second HD4. Then form a SpeedFusion tunnel on the second HD4 to Balance? I remember seeing similar configuration in one of the partner event.
#4
Steve wrote a post about it: active / active config. It requires additional WAN port activation license.
#5
Thank you TK!
#6
Thanks JakubN too!
