Good Afternoon
Could we please have the reasoning why the SpeedFusion Engine is available in LTE-A (Downlink/Uplink Datarate: 300Mbps/50Mbps) but the Ethernet interface only supports 10/100Mbps.
This means that two LTE-A connections would be sharing a single 100Mbps connection.
This is quite a limitation for the projects we where planning on using the SFE for.
The max throughput isn’t also very high. The idea behind the new modems is that they have so much more available frequencies and cover the whole world except APAC.
But I’m with you, more muscles on this magic box is welcome and the price can go up, the form factor is just great.
