speedfusion being control by ic2, if remove the device in ic2, at the same time, it is affect the speedfusion configuration in physical device?
you can not remove the Device from IC2 while there is a SpeedFusion configuration set.
Regards
Dennis
If permanently remove speedfusion in ic2, can we remain the configuration in the peplink device? or we need to reconfigured the speedfusion again?
Hi anonymous,
in this Version of IC2 (2.7.3) you delete the SF Tunnel also on the device.
Then you have to reconfigure SF on the local devices.
I’m not shure what happens if you disable the IC2 Management before deleting the device… (In my opinion, not a good Idea)
I don’t understand why do you want to remove the devices from IC2?
Regards
Dennis
Hello Anonymous,
There are a multiple of a ways to maintain your SpeedFusion settings & still be able to remove the device from InControl2, though as @dennis.hofheinz mentioned, why do you need to remove the device? The options and processes to remove a device from InControl2 while maintaining the settings are known by most Certified Peplink Engineers and has also been previously posted here in the forum.
Happy to Help,
Marcus
