We have a number of VPN’s running between our on site Max BR1’s and our hosted Balance 710. Does the order in which the VPN is brought up (either from the 710 host first or from the Max BR1 first) effect the VPN’s operation ?
Can’t think of a reason why the order might make a difference to operation off the top of my head. Are you seeing an issue you suspect might be caused by this?
Thanks Martin it’s just we have an intermittent inter site problem with SIP calls going one way transmittion and I just wanted to check that the order of restart won’t effect the routes when the VPN is updating it’s connection
