I have downloaded the Speedfusion Cloud Evaluation License pack installed in my Amazon Cloud. Now I need to configure my Pepwave MAX On-The-Go MAX-OTG-U4-SF to establish Speedfusion bonding to stream my vidoeos live. Appreciate someone can describe the configuration settings at Max OTG end to bond with Amazon cloud where the Speedfusion Server Software solution is installed. Please help
On the MOTG end, define the Remote IP address, Remote ID and password if you are using one. FusionHub will just define the password and Local ID of MOTG:
http://www.peplink.com/knowledgebase/configuring-speedfusion-site-to-site-vpn-for-star-scenario/
