My peplibk Soho surf mk3 is not showing any connected clients on the network tab. I need to assign a static IP to a device that is currently on my WiFi network…but it is not showing up. Any ideas? I’ve updated to the most current firmware FYI.
Are you able to check on the device itself what IP address it has?
Are you looking in the right place? Connected clients are in the Status tab, not the Network tab. For good luck, use a browser with no extensions installed. And, try the Peplink app to see if the data is there but your browser isn’t showing it for some reason.
