No problem peparn! The more information everyone can provide, the quicker the problem is found and fixed. Your case #2 sounds like what I’ve seen. Wifi is gone but outbound connections for wired devices somehow still work. This is half and half here.
I should have stated the peplink is plugged directly into the back of an AT&T router. When I had the AT&T router restarted, the wired connections that were on the VLANS with the wireless devices, they could no longer re-establish connections with their cloud component after the AT&T router came back up. But, the raspberry pi’s, which are on a separate VLAN, were able to re-establish outbound connections to their cloud component.
Maybe it’s coincidence, but the issues impacted the clients/systems on VLANs that had a WiFi component to them. I’ll have to keep a log of how long I go between the freeze ups. I believe I updated to firmware 7.1.1 back in August (I need to go look, I have it written down), and have experienced this only three times, so definitely not as frequently as you, but still more than I’d like.
Thanks for the update on the watchdog component too. I was debating turning that on but have not done so yet.
