SOHO & Active Portal
#1
I purchased and installed Captive Portal for the Surf SOHO. Installed w/o a hitch! I see the Captive Portal option but I now need documentation on how to setup. All other Captive Portal documentation does not jive with the Surf SOHO & InControl screens.
Thanks all
Peplink ROCKS!
#2
I would take a look at our knowledge base for setting up CP via IC2 or through the web admin:
http://www.peplink.com/knowledgebase/?s=captive+portal
#3
Having issues, will await documentation.
#4
Hi Robert,
Captive portal does not supported by Surf Soho. For more information, please refer to the Surf SOHO technical specifications below:
Thank You
#5
Hi sitloongs
Hate to break the news to you but Peplinks Surf SOHO does indeed support Captive Portal.
How do I know this? I just purchased the activation key from Peplink;
Captive Portal activation on SOHO SUS-SOHO-LC-CP US$69.00 1 US$69.00
Might want to pass the word to your staff.
Such a new product support does not even know about it! LOL
Robert
#6
I believe sitloongs was meaning to say that the Captive Portal is not a standard feature of the SOHO, but can be activated with a license purchase. Thanks!
#7
I believe sitloongs stated “Captive portal does not supported by Surf Soho” Might want sitloongs to reply to his own post.
Awaiting supporting documentation.
#8
Please refer to previously mentioned knowledge base link for CP support documentation. If you could clarify on what specific issues you are having with setting up CP.
#9
Hi Robert,
Standard license doesn’t come with the Captive Portal feature. I may missed the first post that you mention you have purchased the captive portal license & installed the license. I through you have installed a Surf SOHO but can’t find the captive portal option is available. While you can found the option in userguide.
Possible please share your requirement for the captive portal and i will send you the step to step guide for the setup.
Thank You
#10
Hi Peplink Team, is the captive portal still a required license to purchase if you would like the feature, or does it come with the SUS-SoHo standard?
#11
It is not standard and requires a license key purchase. Thanks.
