Site to Site VPN using IPSEC
I try to create a site to site VPN using IPsec, but I received this error from pep link
IPsec: Refused Main Mode connection request from 202.188.208.245
are there any ways to troubleshoot it?
hi, its interesting. your problem solved ? is there any configuration we can see overall network ?
You need to make sure your IKE setting match on both side:
Same key
Correct local and remote addresses
Same encryption settings.
Confirm that there is no firewall in place which will prevent the connection etc.
thanks
James
