Show active sessions under Layer 2 SpeedFusion
Hi Peplink,
I found VPN active sessions will not display under Layer 2 SpeedFusion.
That can help to monitor or debug if need.
Thank you.
Peplink router will act as bridge (layer 2) after layer 2 SpeedFusion was established. Active session will not happen in the bridge device. You may need to check the active session at the gateway device (gateway for the broadcast domain).
