Does anyone tested before what if SF VPN is over the throughput stated over the datasheet?
for example; peplink 210, VPN bonding throughput support up to 80mbps, what if I got 2 x 100mbps broadband, what it will be happen?
Hi Lai,
the VPN-Throughput ist not throttled to any value. The router will deliver the maximum value to which it is capable. It depends on the size and type of your IP-pakets.
It could be possible that you have sometimes more than 80Mbps, but you should not rely on it. The IO-System of the router is the limiting factor.
If you need more, you should use a bigger router
Regards
Dennis
