I’ve been working with Peplink devices for over 6 years now, during this period I’ve developed a streaming backpack in Brazil based on Peplink SF Bonding capabilities.
Right now I’m developing a new system, much smaller and controlled via smart phone or Web Gui. And I have one request.
My goal is to create a easy to use system, so that the user can control everything inside my API. The encoder interface is basically ready now, but would be amazing to be able to provide SF information in real time inside my API, the goal is to create a user friendly interface.
Is that something possible to do? Could the tech team of Peplink provide me such access? I basically need this info inside my API.
Yes this is possible - although not officially supported so be ready for a journey of discovery and trial and error, and be prepared to have to edit your solution when new firmware is released.
The content of that view comes from calls to the api.cgi page on the local device. If you login to the device and then visit:
It doesn’t contain all the information needed, specially the most important, such as which modem is connected to the SF tunnel and the individual RX/TX speed and latency. Is there any other way to obtain this info?
Also this command presents a problem to integrate it do my API, I need to be logged in to the Peplink Admin, otherwise it won’t work. Is there any other way to access this information by not being logged?
It works fine for me. Here is an example response. Authentication against the webui is a real pain in the ass though… I have automated that with a web user experience test tool, so that it logs in on the web ui via a browser and then the API call happens.
Hi all and @TK_Liew , I was reviving this thread since we are in the same situation and looking for that same data via the API.
Has there been any feature updates to provide this data via the API? I looked through it everywhere and can’t find this data, although it exists in JSON format when using the http://[IP-ADDRESS]/cgi-bin/MANGA/api.cgi?func=status.pepvpn&infoType=peer+profile+tunnel&size=500&searchPattern=&tunnelOption=1-1 link
