Settings from a Surf SOHO MK3 on a Balance 20X?
I am upgrading my SOHO MK3 to a Balance 20x. Instead of having to redo all my settings, can I just restore the settings from a SOHO backup to my new Balance 20x?
Not directly as the config files are not compatible. However you could import a good chunk of the settings (eg firewall rules, grouped networks, outbound policies etc) into InControl and then apply them to the new Balance 20x from there.
is there a guide for importing the settings into InControl?
THANK YOU
Not specifically. No. There is an old InControl2 user manual that Erik DeBie wrote here and it talks about importing the firewall rules for example:
https://knowhow.peplink.ninja/documentation/network-settings/firewall-rules/
But that is not being maintained anymore by my old company… (eg SSL cert has expired)
