Hello guys,
I’m having trouble to set up a SF on FusionHUB behind a Balance 210, here is my setup:
1 - Balance 210 with SF capabilities and 2 SF channels already in use
2 - 2 WAN’s connected to Balance 210, both static IP’s and no firewall
3 - Computer with FusionHUB connected to one of the LAN ports of Balance 210
4 - I’ve made forwarding rules for ports 32015 TCP and 4500 UDP to LAN ip of the FusionHUB.
5 - SF clients are set to target the WAN’s ip on Balance 210.
Am I missing something? Is that possible to do?
You need to do changes below:-
- Change FusionHub Handshake port
Network > SpeedFusion > Follow settings below
- Change FusionHub Data port
Network > SpeedFusion > Select SpeedFusion profile then follow settings below
- Change SpeedFusion clients Handshake port
- Do Port Forwarding for TCP 33015 and UDP 4700 on B210.
Hope this help.
Thank you Liew, that worked perfectly.
Excellent information.
@Liew, any suggestion to edit handshake port when using IC2 PepVPN configuration?
Thanks!
@hcardenas, this is configurable in the device only at the moment.
