Set up a communication route between 2 routers
Hey everyone, I’m fairly new to peplink.
I’m supposed to connect two routers, Max Transit Mini and UBR LTE (each has a cellular Simcard) together. The only viable option may be through a VPN connection since IPs are not public.
I’m looking for a step-by-step guide on how to set up a communication tunnel between the two routers.
Hello Sep,
You need to set up relay server on one device and relay client on other.
Here is step by step tutorial:
https://forum.peplink.com/t/configure-peplink-relay-server-and-client/6215ca9b017e48e0f3ff2479/
Regards,
Laurynas
