When I set the inbound access service, I can select more than 1 server in the “Included server(s)”, but is there any mechanism to check the healthy of servers? If one server is failed, will Peplink assign other available servers for inbound access? Thanks.
Hi Sio,
Thank you for the question. Regarding Inbound Access, you can definitely choose more than one server for a rule. What this does is distribute the request to the selected servers according to the Weight value defined for each server, basically setting up a ratio for distribution.
There really is not a “health check” there for the server that the Balance uses.
