Separate groups for each location?
I’m setting up my first org inside of InControl2 and I’m trying to figure out if I should create a separate group for each of our locations or if it’s ok to just run all in the same group?
At this time we are only putting HD2 devices at each location.
What would you all recommend and what’s the pros and cons of each.
Thanks!
