Security key
Hi, New in the forum,
I’m in trouble with Max BR1, i make a reset for recovery password but now ask to me for a security key. I don’t have it. what happens?
What can i do for get in to the web admin?
Thanks so much.
Please open a support ticket for follow up:
http://cs.peplink.com/contact/support/
The first that i do was this,(your answer), i try to do this for hundred times. All begin when upgrade to 6.2 firmware. I can see the wifi but when i try to connect it ask for a security key and not for the web admin, for take the router signal. Please some solution…
Plug your computer into the LAN Ethernet port on the BR1 and you can access the web admin at 192.168.50.1 and the username and password are both admin by default.
Then you can set the Wi-Fi security key to your liking.
