Please tell me how to get into the BR1 after default reset,It now requires a security key.
Below are things i did already.
1.I already plugged in a lan connect,wont open it up to reset passwords.
2.Used every number on the back of the unit as a security key.
3.No firmware upgrade required on this unit.
Come on folks i cant be the only one here dealing with this!
Default IP address is 192.168.50.1 and username and password for both are admin
Hi Tim ,Thank you I am aware of this, FYI you dont get anywhere without the security key.
What security key are you referring to? Do you have a screenshot?
No security key is needed if you are connected via Ethernet to a LAN port on the BR1. Your PC should have DHCP enabled for the Ethernet connection and it should be getting an IP address like 192.168.50.10
Hi Tim ,im sorry I cant send a pic on this thread,computer can see the BR1 and requires a network security key to access ,It wont open the login page
when I type it into the browser .The BR1 wi fi signal is visable.It wants a security key to access ,thats as far as it goes.
Thank you
It’s a “connect to a network” security key probably something on the computer end of this.
Thank you
It is recommended to connect via Ethernet cable for initial configuration. If you are connecting via Wi-Fi then it will be the last 8 digits of the MAC address which is located on the silver label of the device.
Yes been trying with ethernet cable ,no luck, all was fine untill “restore to factory defaults”
The screenshot you sent is asking for the Wi-Fi password so you are not connecting via Ethernet. I suggest you disable the Wi-Fi altogether on your PC and try again.
If you need help on how to operate your PC you may need to seek help from a friend or colleague.
OK Im In and on the login page!,My mistake was hooking ethernet cable to Home WI FI modem/router which worked before for getting in and set up.
The Fix was acheived by connecting the BR1 directly to my computer with ethernet cable, then when i put in the 192.168.50.1 into the browser the computer picked it up and i was on the login page.
