See, pushback.
High availability is a completely different can of worms, which doesn’t work for my use case, See: Peplink | Pepwave - Forum
High availability only works with a primary unit, and the backup unit becomes useless, until called into action by VRRP.
My primary goal is a network which continues to function if any one component goes down, the network may be unattended for long periods (weeks), so this has to happen automatically, or remotely, preferably automatically. I’m also looking to have two fully functional routers, each which have their own usual jobs, not least as WiFi access points, until the other goes down. It would be a perfect use case, if Peplink did high availability in what seems like a sensible manner to me. (See Sample Configuration 2 in the RFC.)
In the absence of high availability, I’m using the multiple DHCP server approach. Each serves a common pool of allocations for most devices, and from non overlapping pools of addresses for devices I never added to the allocations. Each specifies itself as the router, so if the other goes it’s clients still have somewhere to send their traffic. I’ve using a couple of VWANs to route outbound traffic via the other connection, if necessary via the other Balance unit.
In the absence of high availability, any devices unfortunate enough to be attached to the wrong router when it goes down have to wait for their lease to expire, then when looking for a new lease, they’ll find the other Balance unit, and start again. The lease is 2 hours, so there will be downtime, but things will eventually recover (automatically).
The only device I’ve found which can’t live with that is a Google Chromecast with Google TV. That’s very disappointing that the Android platform seems to have such a problem.
For reference RFC 2131 about DHCP has this to say in section 1.6 Design goals:
A DHCP client must be prepared to receive multiple responses
to a request for configuration parameters. Some installations
may include multiple, overlapping DHCP servers to enhance
reliability and increase performance.
So I have no idea why people recoil in horror whenever I mention this concept.
I even got told, not for the first time,
Please note that there can only be one DHCP server (one router) on the network,
In my latest support ticket. It gets tiresome.
