Is it possible to search device by Vehicle ID in IC2 portal?
We have assigned vehicle ID to some device but forgot which one!
If not from portal then how about using API?
Thank you.
Thank you.
Hi @fairshare_ani,
Yes this is possible, providing you entered the vehicle ID as a “Tag”.
If so, from the Organisation page of InControl you can select Organisation Settings → Device Management
In the search field, enter the Vehicle ID and this should display the device you are looking for:-
I hope this helps,
Steve
Hi Steve:
Unfortunately, we have set it only in the Vehicle ID field of the “GPS Forwarding” screen.
Thank you.
Ani
