SDX Management Port
On the Peplink SDX and SDX Pro, there is a management interface that is akin to those on other devices like the SD Switch 8 etc. On said switch, you’re able to configure the management port to be whatever IP you’d like for out-of-band management.
On the SDX line, it doesn’t seem like there’s a way to do that, and I’d like to have some kind of out-of-band management on mine for access to InControl. How can I configure the IP on the Management port? It seems that it is stuck being whatever the gateway address of the default “Untagged LAN” is.
It is not configurable…I would put that in as a feature request for sure.
For OOBM, plug a cell modem with an IOT/M2M SIM into it and set it as an independent WAN interface, then exclude it from WAN interfaces in outbound policies, or set it as a failover for *.peplink.com domains. That works for me, and ensure I always have access to the Balance device via IC2 unless the whole thing is crashed.
Moved this to the Feature Request group. Peplink Team - please consider making the management interface address configurable for out-of-band management.
I second this request.
