We have one Peplink Balance One router plus other-brands routers connected to WANs
Can we build a SD WAN in this scenario or do we need to use at least two or more peplink devices?
For full SD-WAN capability you want to use Speedfusion VPN which is a point to point technology.
So you have two options:
Martin, that’s the scenario. 2 sites connected through a wireless gigabit bridge. Both sites use the same multiean peplink gateway. Site n. 2 has an unused backup WAN, would like to use that one somehow…
OK cool. So something like a SDX at both sites would be able to fit here. Move the Wireless Bridge to the WAN of the SDX at both sites, then create a Layer 2 Speedfusion VPN between them to combine all WANs and the P2P link together for hot-failover if the P2P wifi link fails.
Ah OK. SO if you don’t want to put another balance at Site 2 but want to use the backup WAN there then you would need to put the WAN backup in a vlan then plug a WAN of the balance into the core switch with that VLAN ID set.
Genius! Will do that! Thanks
As a follow up on this, traffic from block 2 to the WAN backup (as a VLAN through the Balance One) will flow forward and backwards over the network. It shouldn’t be a major issue as the line capability is of 70M down / 20 Up
Your thoughts?
True yes. Not much that can be done about that unless you can put in another p2p wifi link for the wan only (or upgrade the existing link).
