Hi
Is there a way to set PoE Timer on each switch to turn of and turn on APs and other PoE devices at pre set times?
S
Hi
S
You can define a schedule for PoE ports to control on or off.
To define a schedule, navigate to System > Schedule and the click the “New Schedule” button.
Then navigate to Configure > Switch Ports, choose the port and select the schedule via “PoE Enable”.
Yin
Ok Great - Thanks !
