Can you configure the SD Switch (PSW-48-800W) with a local web interface without using the InControl cloud tools?
Does the switch integrate with Balance routers, in a similar way to the APs?
Yes, you can use local web admin to configure the switch.
Two ways to configure the SD Switch:
