Good evening,
Does anyone know if you can power an Airfiber 5/24?
Good evening,
I’m pretty sure that these cannot be powered by 802.3at or 802.3af. You need to use the 50V, 1.2A PoE GigE Adapter (Included) with them.
Specifications for both radios are listed in the datasheet linked below:
You may want to check the note at the bottom of the link below about MAC addresses and power supply:
https://help.ubnt.com/hc/en-us/articles/215999457-airFiber-Input-Voltage
Datasheet claims 42 thru 58 volts is supported. You should be able to use a 48VDC passive POE adapter.
