Hi and thanks for the quick replay,
I am not sure to understand your point about the static address, those are more details about the connectivity:
The max700 is connected to the internet with four 3g USB dongles (load balancing), those addresses are not static (i asked the ISP and its not possible to have a static addresses with those dongles), but the IP address on the 380 side is static, and till now i have no problem setting the speedfusion, i just add the (380 static address in the speedfusion configuration max700 side).
What i don’t understand is why i am able to access the max700 and not the other devices they are in the same network, when i ping the max 700 interface i get
PING 192.168.0.1 (192.168.0.1) from 5.192.224.221 56(84) bytes of data.
64 bytes from 192.168.0.1: icmp_req=1 ttl=64 time=1507 ms
64 bytes from 192.168.0.1: icmp_req=2 ttl=64 time=1011 ms
— 192.168.0.1 ping statistics —
5 packets transmitted, 2 received, 0% packet loss, time 4013ms
rtt min/avg/max/mdev = 916.304/1101.657/1507.817/207.891 ms
When i ping a device in the same network 192.168.0.17 connected to the LAN port of the max 700 i got
PING 192.168.0.17 (192.168.0.17) from 5.192.224.221 56(84) bytes of data.
— 192.168.0.17 ping statistics —
5 packets transmitted, 0 received, 100% packet loss, time 3999ms
I tried to use the trouble shooting tools that are located in the max700 web interface (ping, trace-route ) to reach devices behind it and still no luck, is there a log file somewhere i can check to help me troubleshoot the problem and get more details about whats going on.
Is there a way to access the max 700 over ssh and from there open a connection to my device behind it ?
