Router vs. SpeedFusion throughput
Dear Guys ,
If I have two Balance 380 devices connected using SF and they use 60Mbps SF throughput , then how much router throughput remains for Internet load balancing ?
Which statement is correct ?
1- Balance 380 can support up to 60Mbps SF and up to 200Mbps router throughput simultaneously.
2- Balance 380 can support up to 140Mbps router throughput for Internet load balancing if all 60Mbps SF throughput is used.
3- Balance 380 can not do any Internet load balancing if all 60Mbps SF throughput has been used.
Please make it more clear for me.
Thanks - Hootan
The throughput figures given are the maximums while running a single type of traffic ( 200 Mbps non-vpn or 60 Mbps SF ).
None of the 3 options is correct. Throughput of mixed traffic will depend on ratio of traffic types going through router.
These we be less than the maximums and dependant on your specific scenario.
-Jonan
Thanks for the reply,
Okay , I’m looking to have a formula helping to choose the device model based on SF and router throughput needed.
Thanks - Hootan
