restricting steam
is it possible to restrict steam to not use the speed fusion connections i figure this would be under a firewall rule or under qos applicaion any direction or help would be appreciated i have a balance 20x with 2 connections and 2 computers but only 1 uses steam at all
you can try to find steam IPs and make a group, but i have found no good way. best to just choke the client.
