Hi Team,
I have an opportunity and I need some additional info on APone
I need a confirmation if the AP one enterprise supports the following features :
- interoperable with firewalls Fortigate 1500D
- EAP-TLS, EAPv0/EAP-MSCHAPv2, PEAPv1/EAP-GTC EAP-SIM, EAP-AKA,EAP-FAST
- 802.11e, 802.11h, 802.11i, 802.11j, 802.11x
- 802.11ac 80MHz Channel
- 802.11n Feature: Increased maximum Frame transmission by incorporating A-MPDU and A-MSDU Packet Aggregation
- 802.11n Feature : Conserve power via Dynamic MIMO power save
- Advanced 802.11n to enhance rate-over-range including: Low-density parity check (LDPC) encoding
- Advanced 802.11n to enhance rate-over-range including: Maximum Likelihood Demodulation (MLD)
- Advanced 802.11n to enhance rate-over-range including: Maximum Ratio Combining (MRC) for improved receiver performance
- Background scan with client access on 2.4 and 5 GHz
- Full-time scan as dedicated Monitor
- Full-time scan with client access on 5 GHz
- Mean Time Between Failures >10 years
