REQUEST 1: MORE USER EDITABLE FIELDS, GROUP, BUILDING LOCATION, ETC.
A FEW USER EDITABLE fields that help someone manage a complex LAN would be great.
• KIND/TYPE (which is currently a HARD CODED LIST) (on the grid you call it “KIND” but in the data selector you call it CUSTOM TYPE.
o For example you do not have type :SOLAR CONTROL PANEL… so I have to select UNCLASSIFIED.
o Which doesn’t make my network more usable, but instead more confusing
• SUBTYPE ( a 30 CHAR field, that allows user values)
• NAME, which can be EDITED
• MANUFACTURER, which can be edited (sometimes the WIFI card manufactuers shows up, not the DEVICE MANUFACTURER)
• LOCATION, where in the house for example, Master Bedroom for example (a 30 CHAR field)
• Remember IOT is now thing like power strips, light bulbs, location is a super valuable field.
