Is it possible to assign different VLANs to the users connected via PPTP or L2TP/IPsec?
The main aim is to define different access rules to each remote user. How can I do it?
Thank you,
Gorka
Thank you,
Gorka
Hi Gorka,
PPTP or L2TP/IPsec will use Untagged Vlan only.
You can’t apply access rule to each remote user since they are not using fixed IP. Can I suggest to make use of Untagged Vlan for remote user only? Then use Internal Firewall rule to restrict the connection from/to Untagged Vlan.
Thank you TK.
The Balance works as a central hub with some SpeedFusion peers (star scenario). I would like to restrict the access to some of those peers to some remote users… but it seems that it´s not possible. Anyway, thank you for your suggestion.
BR,
Gorka
