I have the config of a pepwave but it wont let me log in. I want to know is there a way to recover the password from the password file
Which model is it? Do you have an incontrol 2 account?
its a Pepwave MAX HD2 LTE. I know I can connect to from my IC2 account but was wondering if there is a way to retrieve the password from the saved configâŚ
Not officially no. Config file contents are obscured intentionally. Easiest fix is just to reset the device password via IC2.
thanksâŚits the ânot officiallyâ bit that I was interested inâŚâŚâŚ
Hello @ofarrellp,
If you are an administrator within InControl2 of the device in question, you can from InControl2 recover the last know Admin password without resting by doing this:
- Within InControl2 navigate to the device level
- Click on the blue âShow Allâ
- Click on the â********â on the line of âAdmin User / Passwordâ
You devices last know Admin password will now be visible for you.
Happy to Help,
Marcus
