Has anyone else been experiencing random reboots in firmware 8.1.1?
I have the Surf Solo in the network for about 3 weeks running behind an ATT gateway. The gateway wifi is turned off and the Solo wifi is “always on” with the no scheduled events for the Solo. I have had two times that I know of when the Solo has decided to reboot itself. This was evident because I was playing music and the wifi dropped out. When I checked, the gateway was fine, but the Solo was in the process of a reboot with a red status LED.
I will probably schedule a daily reboot to see if this helps, but I was curious if anyone else had this issue.
Thanks.
