Question about Starlink via WAN and speed fusion
Hello All
I own a MAX-BR1-PRO-5G, and I am using Speedfusion. I am feeding a Starlink via WAN (priority one) in conjunction with an eSIM (also priority one).
Should I disable the Starlink router? Which other setting will you use to optimize Speedfusion with this set-up, knowing that my top priority is video streaming? (I am streaming, so reliable upload is key.)
Thanks a lot for your help!!!
Yes, you should disable the Starlink router and enable Starlink on the WAN connection. Network>WAN>Starlink
This will allow you to monitor and control your Starlink from your Peplink router.
Thanks @Michael_Miller8416
That is appropriately set up on the Peplink.
Any other adjustments you recommend to optimize video streaming?
Thanks again
