Dear, i want know if possible make QoS on Speed Fusion Tunnel ?
Hi Antonio, as long as you are using the most current firmware, the QoS policies do apply to SpeedFusion traffic as well.
Thanks -Tim
hi Tim, are you sure with the current firmware we can do QOS on the speedfusion tunnel?
Yes, the QoS policies apply to both regular traffic and SpeedFusion traffic as well.
Hi Peplink Team, is there a document describe how QoS operate on peplink? For example, I was wondering to know when the QoS is triggered, how a packet is processed in the QoS mechanism and how a low prioritized packet is treated in a long time traffic jam?
Packet is queued into different priority queue, as long as higher priority queue has packet, it will not send packet with lower priority.
