hi Peplink R&D, appreciate if you can put in QOS features into the speed fusion VPN tunnel, like guarantee certain bandwidth for certain application, priority VOIP traffic and etc.
because in malaysia a lot of end users asking about this, because certain application like VOIP very sensitive, they don’t need bandwidth but they need QOS for priority, if peplink cannot handle this, customer need to purchase additional box like sangfor or packat shapper.
Your help on this is much appreciate.
hi Peplink Team, please consider to add in this features. In malaysia we really need this.
thanks.
Hi Lai Tong Lek,
Currently, application QoS has been already supported within SpeedFusion since firmware 6.0, meaning you can give VOIP traffic at a priority. Please see if this is working well for you.
Committed bandwidth is an item for consideration in future.
Thanks.
hi keith, which mean when I create QOS-priority at peplink it can apply to the traffic that thru the speed fusion VPN as well?
but committed bandwidth is still not there yet?
thanks.
Yes, this is exactly correct. Thanks.
hello, just would like to clarify the current status of this.
QoS on application is also implemented on the speedfusion tunnel?
Limiting bandwidth per application is still not available in the speedfusion tunnel?
Limiting bandwidth per application is still not available in normal WAN link?
Hi Reynaldo,
We will improve QoS on application over SpeedFusion. Fyi, this involved major changes in the design, so will not happen in near future. However, we are working on an alternative solution to achieve this. Stay tuned.
This same to the limiting bandwidth per application, we will look into this.
Thank you.
