I only see WAN1 & WAN2 for Bandwidth Reserviation on Router BPL-031-LTEA-W and not WAN LTE and USB is this how it is? I use Firmware 8.0
This is normal. The LTE WAN and USB WAN are cellular connections and you cannot define a set bandwidth like you can for wireline connections.
Ok, thanks. So I need a LTE Modem. Then plug it into wan1/2 to use QoS?
