By default, the LAN ports on Peplink routers are configured as Port Type: Trunk, VLAN Networks: Any, and PVID: Untagged LAN (1).
This default configuration is suitable for connecting a Peplink AP, as the AP uses untagged traffic through its WAN port to establish its management connection with the Peplink router’s AP Controller.
Therefore, no changes to the default LAN port configuration are required when connecting a Peplink AP using the default management settings.
The PVID determines which VLAN incoming untagged traffic is assigned to on the router’s LAN port. This is similar to the behavior of an access port, where untagged traffic is assigned to a specific VLAN, except that a trunk port can also carry traffic from other tagged VLANs.
For a LAN port dedicated to a Peplink AP, the recommended configuration is:
Port Type: Trunk (default).
VLAN Networks: Any (default).
PVID: Untagged LAN (1) (default).
The Untagged LAN uses the reserved VLAN identifier [1], which cannot be changed.
This allows the AP to communicate with the Peplink router’s AP Controller through the untagged management network while carrying traffic from different SSIDs using their respective VLANs.
For example:
With the default Trunk / Any configuration, the LAN port can carry traffic for the configured VLANs without requiring additional VLAN assignments on the port.
What if you prefer to use a tagged VLAN for AP management?
By default, the Peplink AP uses an untagged management connection through its WAN port to establish communication with the Peplink router’s AP Controller.
If you prefer to use a tagged VLAN for AP management, the recommended procedure is:
Keep the router’s LAN port at its default configuration (Port Type: Trunk, VLAN Networks: Any, PVID: Untagged LAN (1)). This allows the AP to establish its initial management connection with the AP Controller.
Configure the desired Management VLAN ID on the Peplink router under:
Ensure the new management VLAN is configured on the router and can be carried through the LAN port connected to the AP.
Allow the AP Controller to synchronize the updated management VLAN configuration to the AP.
Once synchronization is complete and the AP is confirmed reachable through the new tagged management VLAN, the original PVID setting can be disabled if it is no longer required.
Important: Do not disable the initial PVID configuration before the new management VLAN settings have been successfully synchronized and connectivity through the new VLAN has been verified. Otherwise, the AP may lose its management connection with the AP Controller.
In general, keeping the default Trunk / Any configuration with PVID assigned to Untagged LAN (1) is the simplest and recommended approach for a Peplink router’s LAN port connected to a Peplink AP using the default management settings.
Another advantage of keeping the default PVID configuration is that if the Peplink AP is factory reset in the future, it can still establish its initial management connection through the untagged network and be managed again by the Peplink router’s AP Controller without requiring changes to the LAN port configuration.
Hope the above explain your concerns
