I have purchased a Balance One Core router for one of my clients with 2 AP One Enterprise APs. Both APs are for indoor use.
I was wondering what are the options for providing power to those APs, which are going to be directly connected to the Balance One.
I believe I need 2 PoE injectors (one for each AP), is that correct? If yes, will the ACW-107 fit the bill?
Thank you for support!
