Good Day PEPLink Experts! haha
This is my first post, so go a little easy on me :3
I’ve read the forums and the wiki on passing VPN Traffic through the PEPLink but somehow it doesn’t seem to work properly.
My First Scenario was with a PEPLink Balance 210 as it had drop in mode, but I wanted to change this to 1:1 NAT for proper failover in the event of ISP failure.
In any case here’s the connection Scenario
WAN1(Multiple Statics)} {LAN1 IP eg. 192.168.10.1 (1:1 NAT Static on WAN1) -----ISA1 (with VPN)
----PEPLink—
WAN2(Single Static) } {LAN2 IP eg. 192.168.10.2 (1:1 NAT Static on WAN1)----- ISA2 (with VPN)
VPN Fails at either 619 error or stuck at verifying username and password.
Same ISA Server tested without PEPLink VPN connects fine ofcourse replacing the NAT LAN IPs with the direct Static ones.
Rules to be noted, i’ve changed the outbound policy default rule to prefer WAN2 over WAN1 (Priority)
Scenario 1 - No inbound policy as I dont think that was needed as it was 1:1 NAT’d
Scenario 2 - With Inbound policy and 1:1 NAT but this didn’t work either
Scenario 3 - Remove 1:1 Nat and use inbound policy alone - To test.
Also tried outbound policy for TCP Port 1723 / IP 47 Enforced to WAN1 before the default rule and no dice…
Can anyone enlighten me?
We are using ISP2 for http / https bandwidth primarily
I’ve already looked at Peplink | Pepwave - Forum (Scenario 3)
Peplink | Pepwave - Forum (Scenario 1)
and Scenario 2 is just a hybrid between 1 and 3
I also took a quick look at Peplink | Pepwave - Forum
Any help is appreciated.
Regards
Edit: I realized my Diagram in text didn’t come out properly … but to note the PEPLink is between the WAN Links and LAN Links (Just didn’t space like it should’ve)
