Hi
i use AP One rugged i would like to connect one server to Ethernet port with reserve Ip on dhcp configuration on this device, my problem is :
the wifi ap worked fine with dhcp configure but i can’t get any ip on Ethernet port !
How can i configure Ethernet to get ip from dhcp configure and all wifi device could access to this server?
dlt_lpd, if I understand the original post, the question is why the AP One does not issue DHCP addresses on the second ethernet port. Is that your issue?
The AP One is an access point, not a router on the wired ethernet side. It can issue DHCP to wifi clients if the AP is in router mode. The ethernet ports are used to bring the network to the AP, not as a router on the wired side. The second ethernet port is used to daisy chain to another wired device (which could be another AP or anything else). If there is another DHCP server on the wired ethernet side, those DHCP requests will flow from one wired port to the other, but they are not issued by the AP One itself.
Sounds like you don’t have a DHCP server on your wired LAN?
Please submit a support ticket for support team to check. If device having activate warranty then you should able to get a hardware replacement for this.
I returned my SOHO MK3, after a few months of trouble, and problems not getting better in the dhcp and routing, I gave up. went back to old Linksys. will find another failover or mulithome wireless router.
