We are using a MaxHD2 to provide a satellite wan and 4g backup on 2 sims. The client s using Citrix receiver on a chrome book is there any way of presenting the same public IP address to the Citrix server cluster regardless of wan connection in use. I suspect that this may be a function of Citrix that it needs to know which Public IP address the session will be using.
Hi Simon,
The way I would do that is run a Fusionhub in the cloud (so it has a static public IP) then PepVPN from the HD2 to it and send all traffic over the VPN. That way no matter which WAN is in use on the HD2, the citrix servers will just see the public IP of the Fusionhub as the source IP.
