I have two different Balance 580’s listed below in two separate data centers. I have them setup with the PPTP server option enabled for remote client access to the LAN. Everything works correctly however I am seeing a huge reduction in bandwidth over the VPN. I only see the reduction in the PPTP clients not the PEPVPN connections.
For example one 580 has a 50x50 fiber connection and the other has a 100x100 fiber connection. I get great speeds across the PEPVPN connections but any client (Windows 7 VPN client, Apple IOS, etc.) can only get a max of about 1.5 x 1.5 when testing the speed. The clients’ connections are around 25 x 5 on average.
So my question is – does the 580 have a limit on the speed of the PPTP server?
Here is the information on model and firmware in use.
Model: Peplink Balance 580
Firmware: 6.1.2 build 3071
This is a test / backup unit with no load
Firmware: 6.1.0 build 2863
This is a production unit with ~ 10% load on average
Thanks in advance for any information,
Brandon
